  • For Layer 2 ACL-based rate limiting on VPLS endpoints, ensure that the default TCAM profile is enabled.
    Important
    Important
    Layer 2 ACL-based rate limiting on VPLS endpoints is not supported on SLX 9150/Extreme 8520.
  • Configure Layer 2 filter parameters to match the outer VLAN, VLAN-tag format, and inner VLAN based on the traffic received on a logical interface for which rate limiting is required. For more information on filtering by the VLAN-tag type, see the Extreme SLX-OS Security Configuration Guide.
  • For Layer 2 ACL-based rate limiting to filter known unicast traffic only, configure a rule for a MAC extended ACL with the known-unicast-only keyword. This configuration is supported only for an ingress ACL on an L2_Ratelimit profile. Note that an implicit deny applies for both unknown and known unicast traffic.
To display the Layer 2 ACL bindings, use the show access-list mac command.
To display the policy-map bindings and rate-limiting statistics, use the show policy-map interface command.
  1. In privileged EXEC mode, access global configuration mode.
    device# configure terminal
  2. Create the Layer 2 ACL.
    device(config)# mac access-list extended m1
  3. Add the permit rule for the ACL.
    device(conf-macl-ext)# permit any any vlan 100
  4. Access global configuration mode.
    device(conf-macl-ext)# exit
  5. Create the class map and access its configuration mode.
    device(config)# class-map c1
  6. Add a match statement to the class map.
    device(config-classmap)# match access-group m1
  7. Access global configuration mode.
    device(config-classmap)# exit
  8. Create the policy map and access its configuration mode.
    device(config)# policy-map p1
  9. Add the class map to the policy map and access the policy-class configuration mode.
    device(config-policymap)# class c1
  10. Configure the class map.
    device(config-policymap-class)# police cir 400000
    This step configures the committed information rate for the class map.
  11. Access global configuration mode.
    device(config-policymap-class)# exit
  12. Access the interface configuration mode for the interface where you want to apply the policy map.
    device(config)# interface ethernet 0/1
  13. Apply the policy map to the interface.
    device(conf-if-eth-0/1)# service-policy in p1
  14. For egress rate limiting, enable the L2-Egress-RateLimit TCAM profile and then reboot the device.
    device(config)# hardware
    device(config-hardware)# profile tcam layer2-egress-ratelimit
    device(config-hardware)# exit
    device# reload system
The following example summarizes the commands in this procedure.
device(config-policymap)# exit
