This feature is supported only on devices based on Extreme 8820, SLX 9740, SLX 9640, and SLX 9540.
  1. Enter global configuration mode.
    device# configure terminal
  2. Enter interface configuration mode.
    device# interface ethernet 0/1
  3. Set the QoS scheduler to a strict priority.
    device(conf-if-eth-0/1)# qos rx-queue multicast best-effort-rate 3000
    The multicast best effort data rate is in kilobits per second (kbps) and has range from 704 through 600000000.
  4. Return to privileged EXEC mode.
    device(conf-if-eth-0/1)# end
  5. Verify the configuration.
    device# show qos interface 0/1
  6. Save the running-config file to the startup-config file
This example summarizes the commands in this procedure.
device(config)# interface ethernet 0/1
