Follow these steps to apply a QoS traffic class-to-DSCP map to an egress interface.
qos remark dscp
be enabled before applying “qos traffic class-to-DSCP map”. On L2
switch port “qos remark dscp” cannot be disabled before removing
“qos traffic class-to-DSCP map”.device# configure terminal
device(config)# interface ethernet 2/2
device(conf-if-eth-2/2)# qos traffic-class-cos TcDscpMap
device(conf-if-eth-2/2)# end
device# show qos maps traffic-class-dscp
[Note: CoS = Class of Service, TC = Traffic Class, DP = Drop Precedence,DSCP = Differentiated Services Code Point]
TC-to-DSCP Map: TcDscpMap
In-TC: 0 1 2 3 4 5 6 7
Out-DSCP(DP=0): 00 08 16 24 32 40 48 56
Out-DSCP(DP=1): 00 30 16 24 32 40 48 56
Out-DSCP(DP=2): 00 08 16 61 32 40 48 56
Out-DSCP(DP=3): 00 08 16 24 32 40 48 56
Enabled on the following interfaces: Eth 0/2
The following example shows how to apply a QoS traffic class-to-CoS map to an egress interface.
device# configure terminal device(config)# interface ethernet 2/2 device(conf-if-eth-2/2)# qos traffic-class-cos TcDscpMap device(conf-if-eth-2/2)# end device# show qos maps traffic-class-dscp device# copy running-config startup-config
