Follow these steps to apply a QoS traffic class-to-CoS mutation map to an egress interface.
A QoS traffic class-to-CoS mutation map has been configured.
  1. Enter global configuration mode.
     device# configure terminal
  2. Enter interface configuration mode.
     device(config)# interface ethernet 2/2
  3. Apply the configured QoS traffic class-to-CoS map to the interface.
     device(conf-if-eth-2/2)# qos traffic-class-cos tcCoSMap
  4. Return to privileged exec mode.
     device(conf-if-eth-2/2)# end
  5. Verify the configuration.
    device# show qos maps traffic-class-cos tcCoSMap
      [Note: CoS = Class of Service, TC = Traffic Class, DP = Drop Precedence]
      TC-to-CoS Map: tcCoSMap
                  In-TC: 0  1  2  3  4  5  6  7
          Out-CoS(DP=0): 0  1  2  3  4  2  6  7
          Out-CoS(DP=1): 0  1  2  3  4  5  6  7
          Out-CoS(DP=2): 0  1  1  3  4  2  6  7
          Out-CoS(DP=3): 0  1  2  3  4  5  6  7
          Enabled on the following interfaces:
          Eth 2/2
  6. Save the running-config file to the startup-config file.
Apply a QoS traffic class-to-CoS mutation map to an egress interface configuration example
