Support for IPv4 egress rate limiting is available for SLX 9740/Extreme 8820 devices on the ethernet, port-channels and VE interfaces. Support for ingress rate limiting is also available for VE interfaces. Filtering can be done on Source IP, Destination IP, IPv4 TOS, IPv4 Protocol, L4 Source Port, and L4 Destination Port.
Before you begin, perform the following tasks:
Create a Policy map with the appropriate Class Map and Police configurations.
IPv4 egress rate limiting is only supported on SLX 9740/Extreme 8820 devices.SLX (config)# ip access-list extended ipv4acl
seq 100 permit ip 10.10.10.10 255.255.255.0 10.10.10.20 255.255.255.0
SLX (config)# class-map class-map_1 SLX (config-classmap)# match access-group ipv4acl
SLX (config)# policy-map policy-map_1 SLX (config-policymap)#
SLX (config-policymap)# class class-map_1 SLX (config-policymap-class)#
SLX (config-policymap-class)# police cir 300000 eir 300000000 SLX (config-policymap-class)#
Apply to the interface.
SLX (config)# int eth 0/1 SLX (config-if-eth-0/1)# service-policy out policy-map_1
Apply to the port-channel.
SLX (config)# interface port-channel 10 SLX (config-port-channel-10)# service-policy out policy-map_1
Apply to the VE interface in the ingress direction
SLX (config)# interface ve 100 SLX (config-ve-100)# service-policy in policy-map_1
Apply to the VE interface in the egress direction
SLX (config)# interface ve 100 SLX (config-ve-100)# service-policy out policy-map_1
The following example summarizes the configuration of IPv4 rate limiting on an ethernet interface for egress traffic.
SLX(config)# ip access-list extended ipv4acl SLX(conf-ipacl-ext)# seq 100 permit ip 10.10.10.10 255.255.255.0 10.10.10.20 255.255.255.0 SLX(conf-ipacl-ext)# exit SLX(config)# class class-map_1 SLX(config-classmap)# match access-group ipv4acl SLX(config-classmap)# exit SLX(config)# policy-map policy-map_1 SLX(config-policymap)# class class-map_1 SLX(config-policymap-class)# police cir 300000 eir 300000000 SLX(config-policymap-class)# exit SLX(config-policymap)# exit SLX(config)# int eth 0/1 SLX(conf-if-eth-0/1)# service-policy out policy-map_1 SLX(conf-if-eth-0/1)# exit SLX(config)#
The following example summarizes the configuration of IPv4 rate limiting on a port-channel for egress traffic. For the configuration of the policy-map refer to the previous section.
This example summarizes the configuration of IPv4 rate limiting on a VE interface for ingress traffic.
This example summarizes the configuration of IPv4 rate limiting on a VE interface for egress traffic.
