Follow these steps to apply a QoS CoS-to-traffic class map to an interface.
The incoming packet PCP value can be mapped to an internal traffic class when packet ingresses the switch. You can create a priority mapping table using a CoS-to-traffic Class map. This map can then be applied to an ingress interface to take effect for priority remapping. This feature only maps the incoming packet priority to traffic class.
device# configure terminal
device(config)# interface ethernet 1/5
device(conf-if-eth-1/5)# qos cos-traffic-class tc_1
device(conf-if-eth-1/5)# end
device# show qos maps cos-traffic-class tc_1
Cos-traffic-class map 'tc_1'
In-Cos : 0 1 2 3 4 5 6 7
Traffic-class: 5 5 5 5 5 5 5 5
Enabled on the following interfaces: Eth 1/5
device# configure terminal device(config)# interface ethernet 1/5 device(conf-if-eth-1/5)# qos cos-traffic-class tc_1 device(conf-if-eth-1/5)# end device# show qos maps cos-traffic-class tc_1 device# copy running-config startup-config
