RPL nodes can be in one of six different states in Version 2:
When an ERP topology starts up, each ERN (in Init state) transmits a R-APS (NR). After start-up, the behavior varies by assigned role. The following table shows the initialization process for an ERN.
Message exchange and actions during ERN initialization version 2
RPL owner |
Non-RPL node |
RPL node |
Init state |
Init state |
Init state |
4. Starts the WTR timer. 5. (After the WTR expires) stops sending NR. 6. Sends R-APS (NR, RB, DNF). 7. Enters the Idle state. |
After receiving the (NR, RB, DNF) from the RPL owner:
When the ring is in the Pending state, an ERN flushes the filtering database (FDB) if it receives any of the following state requests:
ITU-T G.8032 Version 1 does not use a Pending state, so from the Protection state ERNs enter the Idle state.
