Dynamic (LACP) configuration
Link Aggregation Control Protocol (LACP) is an IEEE 802.1AX standards-based protocol that allows two partner systems to dynamically negotiate attributes of physical links between them to form port-channels.
If LACP determines that a link can be aggregated into a LAG, LACP puts the link into the LAG. All links in a LAG inherit the same administrative characteristics.
LACP operates in two modes:
The LACP process collects and distributes Ethernet frames. The collection and distribution process implements:
On each port, link aggregation control:
