The following show commands are helpful in diagnosing a variety of LVTEP configurations.
device# show cluster Cluster default ============== Cluster State: Active/Shutdown Bringup Delay: 10 seconds Configured Member Vlan Range: All Active Member Vlan Range: 1-352,456-765,783,785-795 Configured Member BD Range: All Active Member BD Range: 3-5,26-42 No. of Clients: 4 Peer Info: ---------- Peer IP: 10.1.1.26, State: Up Peer Interface: Ethernet 0/41, Source IP: 10.1.1.28 Keep-Alive: ========== IP: 24.1.1.26, State: Down (Source-interface Down) Interface: Ethernet 0/20 (default-vrf), Source IP: 22.1.1.28 Interval: 100ms Role: Secondary Client Info: ------------ Interface Id Description Local/Remote State Exceptions –-------- –- –----------- –------------------ –---------- Ethernet 0/11 11 Spirent 3/3 Up / Down Remote Down Port-channel 20 1020 Server_U27 Up / Up Tunnel 61441 30.30.30.30 Up / Up VLAN mismatch PW 34816 Down / Down Client Down
device# show cluster client 22 Client Info: ------------ Interface: Port-channel 20, client-id: 1020, Deployed, State: Up Description : U27 Local Vlans : 1,61-300 Local Bridge Domains : 20,100 Remote Vlans : 1,61-300 Remote Bridge Domains : 20 DF Elected for all vlans/BDs
device# show bgp evpn routes type inclusive-multicast detail Total number of BGP EVPN IMR Routes : 12 Status A:AGGREGATE B:BEST b:NOT-INSTALLED-BEST C:CONFED_EBGP D:DAMPED E:EBGP H:HISTORY I:IBGP L:LOCAL M:MULTIPATH m:NOT-INSTALLED-MULTIPATH S:SUPPRESSED F:FILTERED s:STALE Route Distinguisher: 6.6.100.6:32779 1 Prefix: IMR:[0][IPv4:6.6.100.6], Status: BL, Age: 1h54m39s NEXT_HOP: 0.0.0.0, Learned from Peer: Local Router LOCAL_PREF: 100, MED: 0, ORIGIN: incomplete, Weight: 0 AS_PATH: Extended Community: RT 100:1073741835 Adj_RIB_out count: 2, Admin distance 0 L2 Label: 11 RD: 6.6.100.6:32779 Route Distinguisher: 7.7.100.7:32779 5 Prefix: IMR:[0][IPv4:7.7.100.7], Status: BI, Age: 1h53m37s NEXT_HOP: 7.7.100.7, Metric: 1, Learned from Peer: 7.7.100.7 (100) LOCAL_PREF: 100, MED: 0, ORIGIN: incomplete, Weight: 0 AS_PATH: Extended Community: RT 100:1073741835 RT 100:268435456 RT 100:0 ExtCom:03:0c:00:00:00:00:0a:00 PMSI Attribute Flags: 0x00000000 Label-Stack: 817163 Tunnel-Type: 6 Tunnel-IP: 0.0.0.0 Extended Community: ExtCom: Tunnel Encapsulation (Type MPLS) L2 Label: 817163 RD: 7.7.100.7:32779 Route Distinguisher: 8.8.100.8:32779 9 Prefix: IMR:[0][IPv4:8.8.100.8], Status: BI, Age: 1h53m29s NEXT_HOP: 8.8.100.8, Learned from Peer: 8.8.100.8 (100) LOCAL_PREF: 100, MED: 0, ORIGIN: incomplete, Weight: 0 AS_PATH: Extended Community: RT 100:1073741835 RT 100:268435467 RT 100:11 ExtCom:03:0c:00:00:00:00:08:00 PMSI Attribute Flags: 0x00000000 Label-Stack: 11 Tunnel-Type: 6 Tunnel-IP: 8.8.100.8 Extended Community: ExtCom: Tunnel Encapsulation (Type Vxlan) L2 Label: 11 RD: 8.8.100.8:32779
device# show bgp evpn routes type mac detail Total number of BGP EVPN MAC Routes : 2 Status A:AGGREGATE B:BEST b:NOT-INSTALLED-BEST C:CONFED_EBGP D:DAMPED E:EBGP H:HISTORY I:IBGP L:LOCAL M:MULTIPATH m:NOT-INSTALLED-MULTIPATH S:SUPPRESSED F:FILTERED s:STALE Route Distinguisher: 6.6.100.6:36865 1 Prefix: MAC:[0][0000.0607.0000], Status: BL, Age: 0h0m53s NEXT_HOP: 0.0.0.0, Learned from Peer: Local Router LOCAL_PREF: 100, MED: 0, ORIGIN: incomplete, Weight: 0 AS_PATH: Extended Community: RT 100:1073745921 Adj_RIB_out count: 2, Admin distance 0 L2 Label: 4097 ESI : 00.000000000000000000 RD: 6.6.100.6:36865 Route Distinguisher: 8.8.100.8:32779 2 Prefix: MAC:[0][0000.0807.0000], Status: BI, Age: 0h5m16s NEXT_HOP: 8.8.100.8, Learned from Peer: 8.8.100.8 (100) LOCAL_PREF: 100, MED: 0, ORIGIN: incomplete, Weight: 0 AS_PATH: Extended Community: RT 100:1073741835 RT 100:268435467 RT 100:11 ExtCom:03:0c:00:00:00:00:08:00 Extended Community: ExtCom: Tunnel Encapsulation (Type Vxlan) L2 Label: 11 ESI : 00.000000000000000000 RD: 8.8.100.8:32779
device# show tunnel brief Tunnel 32769, mode VXLAN, node-ids 1 Admin state up, Oper state up Source IP 6.7.100.67 ( Loopback 2 ), Vrf default-vrf Destination IP 8.8.100.8
device# show tunnel 61441 Tunnel 32769, mode VXLAN, node-ids 1 Ifindex 0x7c00f001, Admin state up, Oper state up Overlay gateway "gw1", ID 1 Source IP 6.7.100.67 ( Loopback 2 ), Vrf default-vrf Destination IP 8.8.100.8 Configuration source BGP-EVPN MAC learning BGP-EVPN Tunnel QOS mode UNIFORM Active next hops on node 1: IP: 10.6.8.8, Vrf: default-vrf Egress L3 port: Ve 3, Outer SMAC: 609c.9f5a.3d15 Outer DMAC: 609c.9f5a.4515, ctag: 0 BUM forwarder: yes Packet count: RX 167993610 TX 995395 Byte count : RX 29902862580 TX 226950060
