The GRE feature has some limitations and
restrictions that you should understand before you configure it.
- The tunnel source and the destination addresses do not support VRF.
- GRE tunnels support only OSPF, ISIS, and BGP.
- QoS mutation configuration on the VE is not
supported, including VEs that are bound to GRE tunnels.
- The maximum number of GRE tunnels supported is 256.
- The routing protocol used for resolving the GRE
tunnel destination cannot be configured under the VE that is bound to the GRE
tunnel.
- GRE tunnels do not support IPv6.
- GRE keep-alive is supported only with the default VRF. If you want GRE keep-alive
in the non-default VRF, configure a static route in the VRF context to reach the
GRE tunnel source.
