Enabling a master VRRP device
This task is performed on the device that is designated as the master VRRP device. For example, Router 1 is the master VRRP device In the figure that follows.
Basic VRRP topology
  1. On the device designated as the master VRRP device, and from privileged EXEC mode, enter configuration mode.
    device# configure terminal
  2. Globally enable VRRP.
    device(config)# protocol vrrp
  3. Configure the Ethernet interface link for Router 1.
    device(config)# interface ethernet 1/6
  4. Configure the IP address of the interface.
    device(conf-if-eth-1/6)# ip address 192.168.4.1/24
  5. Assign Router 1 to a group called Group 1.
    device(conf-if-eth-1/6)# vrrp-group 1
  6. Assign a virtual router IP address.
    device(config-vrrp-group-1)# virtual-ip 192.168.4.1
    For VRRP, the physical router whose IP address is the same as the virtual router group IP address becomes the owner and master.
The following example configures a VRRP master device.
device# configure
