BGP can advertise a stable route that does not need to exist in routing table.
This task configures a static network and sets the administrative distance.
  1. Access global configuration mode.
    device# configure terminal
  2. Access BGP configuration mode.
    device(config)# router bgp
  3. Specify the autonomous system in which your device resides.
    device(config-bgp-router)# local-as 1000
  4. Access IPv4 address family configuration mode.
    device(config-bgp-router)# address-family ipv4 unicast
  5. Configure a static network and set an administrative distance.
    device(config-bgp-ipv4u)# static-network 10.11.12.0/32 distance 300
    This example configures 10.11.12.0/32 as a static network and sets an administrative distance of 300.
The following example summarizes the commands in this procedure.
