The following is an example of a basic Multi-VRF configuration that uses eBGP with OSPF.
The following example topology shows a typical network that uses the Multi-VRF feature to implement Layer 3 VPNs across two directly connected (at Layer 3) Provider Edge (PE) devices. The Customer Edge (CE) devices can be any router or Layer 3 switch that is capable of running one or many dynamic routing protocols such as BGP or OSPF, or even simple static routing. In this example, we use two devices that interconnect all four CE routers with a single link between the two of them.
eBGP configured between PE1 and PE2 with OSPF (Area 0) configured between PEs and CEs
  1. PE1
  2. PE2
  3. CE1
  4. CE2
  5. CE3
  6. CE4
Topology details are listed below.
Table 1. Topology details
Node Description Networks Carries routes . . . Interfaces
PE1
Aggregation
10.1.1.0/24
10.3.1.0/24
0/1
0/2
0/3
PE2
Aggregation
10.2.1.0/24
10.3.1.0/24
0/1
0/2
0/3
CE1
Edge
10.1.1.0/24
10.1.2.0/24
10.1.3.0/24
0/1
0/2
CE2
Edge
10.1.1.0/24
10.1.2.0/24
10.1.3.0/24
0/1
0/2
CE3
Edge
10.2.1.0/24
10.2.2.0/24
10.2.3.0/24
0/1
0/2
CE4
Edge
10.2.1.0/24
10.2.2.0/24
10.2.3.0/24
0/1
0/2
The following configuration examples for PE1, PE2, CE1, CE2, CE3, and CE4 implement the topology above.
The single link between the two PEs could also be replaced by a Layer 2 switched network if direct physical connection between the PEs is not possible. The only requirement for the connections is that the two PEs be directly connected at Layer 3.
In the example topology, because two different VLANs (10 and 20) have overlapping IP address ranges, communication within each customer's VPN across the two PE routers (that is, between CE1 and CE4, and between CE2 and CE3) must be separated by means of two different VRFs ("green" and "red").
