The 5420 Series is a family of high-performance, feature-rich edge switches designed for the next-generation digital enterprise. The 5420 Series universal hardware provides end-to-end secure network segmentation, in addition to advanced policy capabilities, and offers a user-selectable choice of Extreme‘s flagship switch operating systems. The 5420 Series is a uniquely flexible platform that can be deployed across a range of edge and wiring-closet environments.
The 5420 Series consists of 15 models in the 5420M and the 5420F families. The 5420M models include field-replaceable power supplies and fans, and 4 x 1/10/25Gb built-in uplink ports. The 5420F models have a fixed power supply and one or more fixed fans, a second field-replaceable power supply, and 4 x 1/10Gb built-in uplink ports.
Both the 5420M and the 5420F families include 24 and 48-port 1 Gigabit models, as well as 1 / 2.5 Gigabit multi-rate models. Both also provide 30/60/90W PoE capabilities making them an ideal wired backend for wireless APs or in support of next-generation power Ethernet devices, such as digital signage, pan-tilt-zoom cameras, smart lighting, or point-of-sale terminals.
The switch comes with a dual-persona capability, allowing you to choose your Operating System (OS). Either the Switch Engine (EXOS) or Fabric Engine (VOSS) OS can be selected at switch start-up or changed at a later time. The switch assumes the features and capabilities of the OS that is selected. Switch OS selection can also be automated with ExtremeCloud IQ so that the desired OS can be automatically loaded at switch start-up, which facilitates remote OS enablement.
Model 5420M-24W-24S-4YE has a USB Type C port, but does not have a Micro-USB Type B port.After connecting to your switch, it can be flexibly configured and operated though the cloud, the network, or the command-line interface (CLI), either remotely or locally. You can access management functions on the switch using ExtremeCloud™ IQ or ExtremeCloud IQ Site Engine, or manually through a web-based GUI or generic command-line interface (CLI) client. For more information on switch configuration and operation methods, see Manage Your Switch.
There are also two USB 2.0 Type A ports labeled USB 1 and USB 2.Switch onboarding to the cloud is a hands-off operation using zero touch provisioning. Unpack the switch and connect it to the network. It automatically finds a connection to the cloud and is ready to be provisioned. The ExtremeCloud Companion mobile app makes onboarding even easier with on-site cloud set-up and switch troubleshooting capabilities.
Each switch is cooled by one replaceable internal fan module in 5420M switches, or two or three fixed internal fans in 5420F switches. The switch supports front-to-back airflow for switch cooling. Switch fans are not responsible for cooling the power supplies; power supplies have integrated cooling fans that operate independently of the switch fan.
For more information about the fan modules used in the switch, see Fan Modules for Use with Your Switch.
Each switch uses fixed and replaceable internal power supplies to provide enough power for the needs of the switch. 5420F models have one hot-swappable power supply and one fixed power supply. 5420M models have two hot-swappable power supplies. Power supplies have integrated cooling fans that operate independently of the switch fans for power supply cooling and are not responsible for cooling the switch.
Replaceable power supplies are ordered separately.
For more information about the power supplies used in the switch, see Power Supplies for Use with Your Switch.
Each switch comes equipped with two stacking ports, also referred to as Universal Ethernet ports. When running Switch Engine, these ports can be used in either stacking mode or Ethernet mode. When in stacking mode, up to eight systems can be stacked using qualified direct attach cables or optical transceivers. Fabric Engine does not support stacking; the stacking ports can be used as Ethernet ports if Fabric Engine is in non-fabric mode.
5420 Series switches can stack with themselves and with other switches. See Combine Switches from Different Series for more information.Note
This feature is only supported on Switch Engine.Note
Secure boot establishes a chain-of-trust relationship in the boot process. The chain- of-trust is established by cryptographic checks at each stage of the boot process to validate the integrity and authenticity of the next stage before it can execute. The current implementation validates boot images. It cannot be disabled after it has been programmed on the device. There is no command-line interface or commands to enable or disable secure boot. The status of the boot image verification can be monitored in the operating system.
For more information, see Secure Boot.
All 5420 Series switches support an operating range from 0°C to 50°C up to 3000 m (10,000 ft).
Temperature restrictions apply for some models at high altitudes.
5420 Series switches support Unified Licensing, so that you can use them with multiple operating systems. There are two methods of acquiring feature licenses: manual or through ExtremeCloud IQTM (XIQ).
For Switch Engine licensing, see the Feature License Requirements for your version of the Switch Engine operating system.
For Fabric Engine licensing, see the Licensing chapter in the Fabric Engine User Guide for your version of the Fabric Engine operating system.
For XIQ licensing, see ExtremeCloud IQ.
Section contents:
