5420 Series Technical Specifications
External Interfaces
Switch ModelInterfaces
5420F-24T-4XE
24 x 10/100/1000BASE-T ports
  • Full / Half-Duplex(autosensing)
  • MACsec-capable
4 x 1/10Gb SFP+ uplink ports(unpopulated)
  • MACsec-capable
2 x Stacking/SFP-DD ports* (unpopulated)
1 x Serial console port (RJ-45)
1 x 10/100/1000BASE-T out-of-band management port
2 x USB A ports for management or external USB flash
1 x USB Micro-B console port
5420F-24P-4XE
24 x 10/100/1000BASE-T 802.3at (30W) ports
  • MACsec-capable
  • MACsec-capable
5420F-24S-4XE
24 x 100/1000BASE-X (SFP) ports (unpopulated)
  • MACsec-capable
  • MACsec-capable
5420F-48T-4XE
48 x 10/100/1000BASE-T ports
  • MACsec-capable
  • MACsec-capable
5420F-48P-4XE
48 x 10/100/1000BASE-T 802.3at (30W) ports
  • MACsec-capable
  • MACsec-capable
5420F-48P-4XL
  • MACsec-capable
  • MACsec-capable
  • LRM-capable
5420F-8W-16P-4XE
8 x 10/100/1000BASE-T 802.3bt (90W) ports
  • Full Duplex at 1000M, Full / Half-Duplex (autosensing) at 10/100M
  • MACsec-capable
16 x 10/100/1000BASE-T 802.3at (30W) ports
  • Full/Half-Duplex(autosensing)
  • MACsec-capable
4 x 1/10Gb SFP+ uplink ports (unpopulated)
  • MACsec-capable
5420F-16W-32P-4XE
16 x 10/100/1000BASE-T 802.3bt (90W) ports
  • MACsec-capable
32 x 10/100/1000BASE-T 802.3at (30W) ports
  • MACsec-capable
  • MACsec-capable
5420F-16MW-32P-4XE
16 x 100M/1G/2.5GBASE-T 802.3bt (90W) ports
  • MACsec-capable
  • MACsec-capable
  • MACsec-capable
5420M-24W-24S-4YE24 x 10/100/1000BASE-T 802.3bt (90W) ports
  • MACsec-capable
  • MACsec-capable
4 x 1/10/25Gb SFP28 uplink ports (unpopulated)
  • MACsec-capable
1 x USB C console port
5420M-24T-4YE
  • Full / Half-Duplex (autosensing)
  • MACsec-capable
  • MACsec-capable
5420M-24W-4YE
  • MACsec-capable
  • MACsec-capable
5420M-48T-4YE
  • MACsec-capable
  • MACsec-capable
5420M-48W-4YE
48 x 10/100/1000BASE-T 802.3bt (90W) ports
  • MACsec-capable
  • MACsec-capable
5420M-16MW-32P-4YE
  • MACsec-capable
  • MACsec-capable
  • MACsec-capable
* Notes on use of the 2 x Stacking/SFP-DD ports
  1. With Switch Engine, the 2 x SFP-DD ports can be used either for stacking or as Ethernet uplink ports (when not stacking).
  2. With Fabric Engine, the 2 x SFP-DD ports can be used as Ethernet uplinks when in non-Fabric mode.
  3. SFP-DD ports support either 10Gb or 20Gb data rates with the use of appropriate transceivers/cables.
  4. When used as uplinks, 5420M models support up to 2 x 10Gb channels on each SFP-DD port
  5. When used as uplinks, 5420F models support a single 10Gb channel on each SFP-DD port.
Weights and Dimensions
Switch ModelWeight*Physical Dimensions
5420F-24T-4XE4.10 kg (9.03 lb.)
Height: 43.7 mm (1.7 in.)
Width: 441.0 mm (17.4 in.)
Depth: 287.02 mm (11.3 in.)
5420F-24P-4XE4.64 kg (10.23 lb.)
5420F-24S-4XE4.12 kg (9.08 lb.)
5420F-8W-16P-4XE4.64 kg (10.23 lb.)
5420F-48T-4XE4.64 kg (10.23 lb.)
5420F-48P-4XE5.28 kg (11.64 lb.)
Depth: 330.20 mm (13.0 in.)
5420F-48P-4XL5.28 kg (11.64 lb.)
5420F-16W-32P-4XE5.36 kg (11.82 lb.)
5420F-16MW-32P-4XE5.30 kg (11.68 lb.)
5420M-24W-24S-4YE4.47 kg (9.7 lb.)
5420M-24T-4YE4.18 kg (9.22 lb.)
5420M-24W-4YE4.40 kg (9.70 lb.)
5420M-48T-4YE4.39 kg (9.68 lb.)
5420M-48W-4YE4.73 kg (10.43 lb.)
5420M-16MW-32P-4YE5.30 kg (11.68 lb.)
