5420F switches come with one fixed power supply. You can install an additional power supply for redundancy. 5420M switches do not come with installed power supplies. You can install one or two power supplies. All installed power supplies must blow air in the same direction and must match the airflow direction of the installed fan modules. 5420 Series switches are only available with front-to-back airflow.
For installation instructions, see Replace Power Supplies.
