5720 Series Installation Guide
> Korea EMC Statement
Extreme Networks, Inc. March 01, 2026
Introduction to the 5720 Series Installation Guide
New in this Guide
5720-24MW Switch Features
5720-24MXW Switch Features
5720-48MW Switch Features
5720-48MXW Switch Features
Port Subdivisions
Secure Boot
Manage Your Switch
Universal Ethernet Ports
Fan Modules for Use with Your Switch
Fan Modules
Power Supplies for Use with Your Switch
715 W AC Power Supplies
1100 W AC Power Supplies
2000 W AC Power Supply
Expansion Modules for Use with Your Switch
Versatile Interface Modules
5720-VIM-2CE Versatile Interface Module
5720-VIM-6YE Versatile Interface Module
Solid-State Drives
LRM/MACsec Adapter
Maximum Capacity for Using the LRM/MACsec Adapter
Limitations for Some Optical Devices
LRM/MACsec Adapter LEDs
Build Stacks
Introduction to Stacking
Build Basic Stacks
Slot Numbers in Stacks
SummitStack Topologies
SummitStack Terms
Plan to Create Your Stack
Enable and Disable the Stacking Support Option
Recommendations for Placing Switches for Stacked Operation
Recommendations for Configuring Stacks
Combine Switches from Different Series
Select Stacking Cables
Use the Extreme Stacking Tool
Set up the Physical Stack
Connect the Switches to Form the Stack Ring
Examples of Valid Stacking Configurations
Example: Basic Stack with Four Switches
Example: Basic Stack with Eight Switches
Example: Stacked Switches across Several Racks
Connect Your Stack to the Management Network
Site Preparation
Plan Your Site
Set Up the Wiring Closet
Control the Temperature
Control the Humidity Level
Ground the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Requirements for PoE Devices
Power Supply Requirements
Power Cord Requirements
Select a UPS
Install Your Switch
Install Expansion Modules
Install Optional Components
Install Internal Power Supplies
Turn on the Switch
Log In for the First Time on Switch Engine
Change the Switch OS via the Bootloader Menu
Change the Switch OS via the Startup Menu
Log In for the First Time on Fabric Engine
Remove and Replace Components
Remove the Switch from a Rack
Remove a Switch from a Four-Post Rack
Remove a Switch from a Two-Post Rack
Replace Power Supplies
Power Supply Airflow Direction Requirements
Replace a Power Supply
Replace Fan Modules
Fan Airflow Direction Requirements
Replace a Fan Module
Replace Expansion Modules
Replace Versatile Interface Modules
Replace Solid-State Drives
Replace LRM/MACsec Adapters
Monitor the Switch
System Status LEDs
Technical Specifications
5720 Series Technical Specifications
Acoustic Noise and Fan Speed
CPU and Memory
Mean Time Between Failures
Power Specifications
LRM/MACsec Adapter Technical Specifications
Environmental
Standards
EMI/EMC Standards
Console Connector Pinouts
General Safety Precautions
Maintenance Safety
GBIC, SFP (Mini-GBIC), QSFP+, XENPAK, and XFP Regulatory Compliance
Cable Routing for LAN Systems
Select Power Supply Cords
Battery Notice
Battery Warning - Taiwan
EMC Warnings
Japan (VCCI Class A)
Korea EMC Statement
Korea EMC Statement
