Ports, Connectors, and Hardware Features
The AP5060D and AP5060U have the following Ethernet ports:
In addition both APs have the following:
  • A ground terminal for circuit protection.
  • A console port for troubleshooting.
  • One safety hanger.
AP5060D and AP5060U Ports and Connectors
Table 1. Ports and Connectors
NumberLabelDescription
1GroundA ground terminal for lightning protection.
2Vent
3ETH1Ethernet port.
4ETH0Ethernet port.
5ConsoleMicro USB console port for a serial connection between your management system and the access point. Use the port when you troubleshoot the AP.
Tip: The best practice is to use the Extreme Networks micro USB cable (ACC-WIFI-MICRO-USB). When you connect to the device, the management station must have a VT100 emulation program, such as the terminal emulator TeraTerm Pro or Hilgraeve HyperTerminal. Set your baud rate to 115200.
Note: The console port can only be used with the Extreme Networks console cable. You could damage the AP if you use another cable.
