AP5060D and AP5060U Installation Guide
Installation
> Troubleshoot the AP
Extreme Networks, Inc. May 01, 2026
Abstract
Preface
New and Changed
Purchase Order Information
Technical Specifications
Radiation Patterns
AP5060D Antenna Radiation Patterns
AP5060D Sensor Radiation Patterns
AP5060D Blue Tooth Low Energy Radiation Patterns
AP5060U Antenna Radiation Patterns
AP5060U Sensor Radiation Patterns
AP5060U Blue Tooth Low Energy Radiation Patterns
Ports, Connectors, and Hardware Features
LED Descriptions
Radios
Power Profiles Overview
Power Profiles
1Gbps Throughput Power Profiles
Power Options
Enclosure
Accessories
MAC Address
Power or Pressure Washing Guidelines
Installation
Installation Workflow
Box Contents
Pre-Installation Tasks
Configuration for Horizon Rule
Install the Access Point on a Unistrut Structure Using the MBO-ART03 Bracket
Pole Installations
Install the Access Point on a Pole Using KT-147407-02 Bracket Parts
Install the Access Point on a Pole Using KT-147407-02 Bracket Parts and KT-150173-01 Extension Arm
Install the Access Point on a Pole with the MBO-ART03 and KT-147407-02 Brackets
Wall Installations
Install the Access Point on a Wall or Flat Surface Using the KT-147407-02 Bracket Parts
Install the Access Point on a Wall With the MBO-ART03 Bracket
Install the Access Point Using KT-147407-02 Bracket Parts and KT-150173-01 Extension Arm
Install the Access Point Using KT-150173-01 Extension Arm
Install the AP5060U Under a Seat
Install the EIO-04 Underseat Slope Bracket and the Access Point
Install the Access Point on a Flat Surface Using EIO-04 Bracket
Ground the Access Point
Connect the ETH1 or ETH0 Cable to the Access Point
Connect the Service Panel Base and ETH1 or ETH0 Cable
Install the Plastic Service Panel on the Access Point
Secure the Access Point after Installation
Onboard the Access Point with the ExtremeCloud IQ Mobile Onboarding App
Troubleshoot the AP
Reset the AP
Micro USB Console Port Information
Regulatory and Compliance
Country of Manufacture
Professional Installation Instructions
Safety Guidelines
CE Marking and European Area (EEA)
FCC Notice (Part 15 - Class B)
FCC Radiation Exposure Statement
Industry Canada Notice
Mexico Compliance Statement
Brazil Ag??ncia Nacional De Telecomunica????es (Anatel) Statement
China Compliance Statement
Japan (VCCI) - Voluntary Control Council for Interference Class B ITE
Taiwan Regulatory Statement
Thailand Regulatory Statement
United Kingdom (UK) and European Union (EU) Radiation Warning Statement
Extreme Networks UK Address
Extreme Networks EU Importer Address
European Waste Electrical and Electronic Equipment (WEEE) Notice
Declaration of Conformity in Languages of the European Community
Troubleshoot the AP
Use the information in the following sections to troubleshoot your AP.
Section contents:
Reset the AP
