The access point can be attached to a wall or flat surface with:
KT-150173-01 (12 inch extension)
The M6 hex-head screws and screw-in anchors must be provided by the installer.The following hardware is required when installing the access point on a flat surface using the KT-147407-02 bracket:
The M6 hex-head screws and screw-in anchors must be provided by the installer.If you install the access point to the wall using the ART03 bracket, use the following hardware:
The cable glands should face down when you install the access point on a wall.Section contents:
