Access points are automatically added to your network when the DHCP and DNS prerequisites have been met. But you can save time and configure the AP before you install it with the pre-provision mode. You can revert the AP to production mode when you are ready for deployment.
Confirm that Domain Name System (DNS), Network Time Protocol (NTP), and the firewall ports are configured and available before deployment. Create a firewall rule to allow outbound traffic from Extreme Networks devices. For more information about firewalls, see Firewall Configuration Guides.You should configure the DHCP options on your DHCP server to assign an allowed NTP server to Extreme Networks devices. Both DNS and NTP are critical for country and region detection and certificate validation.
For more information on deployment, see ExtremeCloud IQ Controller documentation and the IQ Engine documentation.
Use the information in the following table to help you install your access point.
Warning
Do not stack APs on top of each other during onboarding or configuration. This may cause heat to build up between the APs, damaging the radomes and voiding the warranty.| Steps | Action | Purpose |
| 1 | Confirm that your AP and accessories arrived complete and undamaged. | |
| 2 | Install the access point to one of the following: Install the AP on a pole
Install the AP on a Unistrut: Install the AP on a wall:
| Install the AP on a ceiling or wall, and connect the network cable. If you use Power over Ethernet (PoE), then the AP powers up. The AP begins a discovery process to determine its own IP address and the IP address of the controller. When the discovery process is successful, the AP registers with the controller. For more information, see the following articles:
| 4 | Connect the AP to your network. |
Connect the AP to your network using a network cable and one of the Ethernet ports. Ensure that the other end of the network cable connects to a network Power Sourcing Equipment (PSE). Login to ExtremeCloud IQ Controller and set the operating system (OS) and region. See the "Onboarding Universal APs — ExtremeCloud IQ" section of the ExtremeCloud IQ Controller Deployment Guide. Note: Universal APs are configured for cloud management by default. If you want to manage these APs locally, you must specify Local Management when onboarding the APs in ExtremeCloud IQ.
| 5 | (Optional) Onboard the AP with the ExtremeCloud IQ Mobile Onboarding application. | Scan the QR code or bar code on the back of the device and begin the onboarding process. |
| 6 | Confirm that the LED is white. | A white LED indicates that your AP has powered up and registered with the Cloud. An amber light indicates a technical issue that requires a resolution. See the Led Descriptions section in the "Overview" chapter for an explanation of the LED states. |
| 7 | (Optional) Secure the Access Point. | Secure the AP and prevent it from falling. |
