Power Profiles
The following tables show the AP5060D and AP5060U power profiles for the radio modes. Use this information to plan for power consumption as you deploy your APs.
Table 1. 802.3at Power Profile With Scan
Radio Operational ModeRadio 1Radio 2Radio 3Scan 2x2IoTPSEFunction
Mode 1
2.4/5/6 GHz
802.3at
2.4 GHz
16dBm
2x2
5 GHz - Full
17dBm 3x3
40MHz
6 GHz
16dBm 3x3
80MHz
Yes
Yes
No
Tri-band Radio + Scan, IoT
Mode 2
5L/5H/6 GHz
802.3at
5 GHz Low
16dBm
2x2
40MHz
5 GHz High
16dBm
2x2
40MHz
6 GHz
16dBm
3x3
80MHz
Yes
Yes
No
Dual 5 GHz w/6 GHz + Scan, Iot
Mode 3
5/6L/6H GHz
802.3at
6 GHz High
16dBm
2x2
80MHz
5 GHz
16dBm
3x3
40MHz
6 GHz Low
16dBm
2x2
80MHz
Yes
Yes
No
Dual 6 GHz w/5 GHz + Scan, Iot
Table 2. 802.3at Power Profile Without Scan
Mode 1
802.3at
2.4 GHz
14dBm
2x2
5 GHz - Full
14dBm 4x4
40MHz
6 GHz
14dBm 4x4
80MHz
No
Yes
No
Tri-band Radio + IoT
Mode 2
802.3at
5 GHz Low
14dBm
3x3
40MHz
5 GHz High
14dBm
3x3
40MHz
6 GHz
14dBm
3x3
80MHz
No
Yes
No
Dual 5 GHz w/6 GHz + Iot
Mode 3
802.3at
6 GHz High
14dBm
3x3
80MHz
5 GHz High
14dBm
3x3
40MHz
6 GHz Low
14dBm
3x3
80MHz
No
Yes
No
Dual 6 GHz w/5 GHz + Iot
Table 3. 802.3bt Power Profile
Mode 1
802.3bt
2.4 GHz
18dBm
4x4
5 GHz - Full
18dBm 4x4
6 GHz
18dBm 4x4
Yes
Yes
Yes
Tri-band Radio + Scan, IoT, PSE
Mode 2
802.3bt
5 GHz Low
18dBm
4x4
5 GHz High
18dBm
4x4
6 GHz
18dBm
4x4
Yes
Yes
Yes
Dual 5 GHz w/6 GHz + Scan, Iot, PSE
Mode 3
802.3bt
6 GHz High
18dBm
4x4
6 GHz Low
18dBm
4x4
5 GHz
18dBm
4x4
Yes
Yes
Yes
Dual 6 GHz w/5 GHz + Scan, Iot, PSE
