Airflow Direction Requirements
All installed power supplies must blow air in the same direction and must match the airflow direction of the installed fan modules.
  • If the power supply has a red tab, the airflow is front-to-back.
  • If the power supply has a blue tab, the airflow is back-to-front.
The operating-system software cannot display the airflow direction.
