Extreme 8730 Technical Specifications
The following tables contain external interfaces information and weights and dimensions information for the switch.
External Interfaces
InterfacesDescription
Ports
  • 32 x 40/100/400Gbps QSFP-DD ports (backwards compatible to QSFP-28)
  • 2 x 1/10Gbps SFP+ out-of-band management ports
  • 1 x RJ-45 Serial console port
  • 1 x USB A port for management or external USB flash
  • Global Navigation Satellite System for GPS signal
  • HD-BNC connector for Time synchronization, 1PPS and 10MHz
  • Advanced services port for the processor to offload to external appliance
  • TOD (Time of Day), 1PPS signal inputs
Power Supplies
  • Modular 1600W AC power supply (up to 2 PSUs)
  • Modular 1600W DC power supply (up to 2 PSUs)
  • Front-to back and back-to-front airflow options
Fan Tray
  • 7 fan modules, support one fan redundancy
Dimensions
  • 17.3in W/24.9in D/1.71in H (439.6mm W/633.5mm D/43.5mm H)
Weight
  • 28.0 lb (12.7 kg) with no PSU / 32.4 lb (14.7 kg) with two PSU
Weights and Dimensions of Accessories
ModelWeightDimensions
XN-FAN-006-FB: Fan, front-to-back
XN-FAN-006-BF: Fan, back-to-front
0.18kg (0.39lb)
42.0mm W x 40.9mm H x 136.7mm D
(1.65 in W x 1.61 in H x 5.38in D)
XN-ACPWR-1600W-FB-A: PSU, front-to-back
XN-ACPWR-1600W-BF-A: PSU, back-to-front
2.69lb (1.22kg)54.5mm W x 40.2mm H x 352mm D
(2.15in W x 1.58in H x 13.86in D)
XN-DCPWR-1600W-FB-A: PSU, front-to-back
2.77lb (1.26kg) 54.5mm W x 40.2mm H x 352mm D
XN-4P-RKMT302 - Four-post rack mount kit (included with switch)
2.84kg (6.26lb)
70mm W x 50mm H x 72.0mm D
(2.76in W x 1.97in H x 28.4in D)
XN-2P-RMKIT-005 - Two-post rack mount kit (ordered separately)
0.17kg (0.375lb)
44.1mm W x 20.2mm H x 80.0mm D
(1.74in W x 0.8in H x 3.15in D)
