Power Specifications
The following topic contains power specification information for the switch. Refer to the Extreme 8730 Data Sheet for up-to-date information.
Power Supply Specifications
Power Supply Specifications includes power supply specifications for the switch.
Table 1. Power Supply Specifications
1600W AC PSU
XN-ACPWR-1600W-FB-A
XN-ACPWR-1600W-BF-A
1600WDC PSU
XN-DCPWR-1600W-FB-A
XN-DCPWR-1600W-BF-A
Voltage Input Range100-120/200-240VAC-48 to -60VDC
Line Frequency Range50Hz– 60HzN/A
Input Rating12/6A Max. for each PSU30A Max. for each PSU
PSU Input SocketIEC320 C16
IEC 320 C14
Terminal Block
PSU Output CordIEC320 C15
IEC 320 C13
N/A
Operating Conditions0°C–45°C operation0°C–45°C operation
Power and Heat Dissipation
Power Supply Specifications and Power Consumption include power consumption and power and heat dissipation for the switch.
Table 2. Heat Dissipation
Switch Model Minimum Heat Dissipation (BTU/hr) (Idle,no ports linked)Minimum Power Consumption (Watts)(Idle, no ports linked)Maximum Heat Dissipation (BTU/hr) (Fanshigh, all ports 100% traffic) Maximum Power Consumption (Watts) (Fans high, all ports 100% traffic)
8730-32D 1709.48 BTU/hr5014671.2 BTU/hr 1371.95
Table 3. Power Consumption
Max 8730-32D Power Consumption (Watts) Vin (Vrms)Max AC PSU Power Output per AC PSU (W) Minimum Number of AC PSUs Required N+1 Redundancy
1371.95100-12710002Yes
1371.95200-24016001Yes
