Extreme 8730 Installation Guide
Extreme Networks, Inc. July 01, 2025
Introduction to the Extreme 8730 Installation Guide
Extreme 8730 Overview
8730 Series Switch Features
Manage Your Switch
FEC Configuration Support
Fan Modules for Use with Your Switch
Fan Modules
Power Supplies for Use with Your Switch
1600 W AC Power Supplies
1600 W DC Power Supplies
Site Preparation
Plan Your Site
Set Up the Wiring Closet
Control the Temperature
Control the Humidity Level
Ground the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Power Supply Requirements
Power Cord Requirements
Select a UPS
Install Your Switch
Install Optional Components
Install Internal Power Supplies
Turn on the Switch
Login for the First Time on Extreme ONE OS
Remove and Replace Components
Remove a Device From a Rack
Remove a Device from a Four-Post Rack
Remove a Device from a Two-Post Rack
Replace Internal Power Supplies
Airflow Direction Requirements
Replace a 1600 W Internal AC Power Supply
Replace a 1600 W Internal DC Power Supply
Replace Fan Modules
Replace a Fan Module
Monitor the Device
System Status LEDs
1G/10G SFP+ Management Port LEDs
QSFP-DD Port and Sub-channel Selector LEDs
QSFP28 Port LEDs
Power Supply LEDs
Technical Specifications
Extreme 8730 Technical Specifications
Acoustic Noise and Fan Speed
CPU and Memory
Mean Time Between Failures
Power Specifications
Environmental
Standards
EMI/EMC Standards
Console Connector Pinouts
General Safety Precautions
Maintenance Safety
GBIC, SFP (Mini-GBIC), QSFP+, XENPAK, and XFP Regulatory Compliance
Cable Routing for LAN Systems
Select Power Supply Cords
Battery Notice
Battery Warning - Taiwan
EMC Warnings
Japan (VCCI Class A)
