You
can use the ICC1 port to connect to the appliance for initial setup. Note that the ICC1
port has a defined IP address, but you must set your laptop to use the same network
segment.
Connect a laptop to the appliance management port.
Configure the laptop Ethernet port of the laptop with a statically assigned
unused IP address in the 192.168.10.0/24
subnet.
SSH to the appliance.
192.168.10.1 is the default IP address on the appliance management port).
The Universal Compute Platform logon screen is displayed.
