To ensure that the
replacement node successfully joins the cluster, set the VRRP node
priority of the replacement node to a value that is lower than the
value of the existing nodes. This ensures that the VRRP address is
pointing at a working node in the cluster during the joining
process. After the replacement node has joined the cluster, you can
set the VRRP node priority to first priority if desired, but this is
not required.
