Non-routable container orchestration by Kubernetes within the cluster requires reservation of private non-routable network segments for each Pod. Plan for network segmentation regardless of your deployment mode.
Review the default IP range values for your pod and service networks in the following table. Use them if they are suitable and do not conflict with the deployed infrastructure network routing definitions. If there is a conflict, adjust the segment IP range as required. Make sure to use private non-routable address spaces for any ranges that you adjust.| Restricted IP Range | Default Value | IP Address /Range |
| Application Network IP Range | 10.0.2.0/24 | <reserved ip>/24 |
| Pod Network IP Range | 10.96.0.0/16 | <reserved ip>/16 |
| Service Network IP Range | 10.97.0.0/16 | <reserved ip>/16 |
| Internal Docker IP Range | 172.17.0.0/24 | <reserved ip>/24 |
| Internal Component Networking | 172.31.0.16/28 | <reserved ip>/28 |
VRRP operations require visual representation of where the IP addresses are allocated.
