ExtremeCloud Edge v5.14.01 Managed Orchestration Deployment Guide
> Revision History
Extreme Networks, Inc. June 22, 2026
Abstract
Revision History
Preface
Introduction
Managed Orchestration Cluster
Kubernetes
Supported Appliances for Managed Orchestration
Deployment Responsibilities
Requirements
ExtremeCloud Edge Planning
Firewall Access for Critical Settings
Availability Zones
Prerequisites for ExtremeCloud Edge Installation
IP Addresses
VRRP Configuration
Reserved IP Addressing
Port Information for Firewalls
Source Address Information
Configure the Deployment
Connect to the Appliance through the Console Port
Connect to the Appliance through the ICC1 Port
Run the Basic Configuration Wizard
Upgrade the Appliance Software
IP Address Configuration
Configure VRRP (VIP)
Configure the Cluster Settings
Run Readiness Assessment
Install ExtremeCloud IQ Engine
Network Service Configuration
Validate the Cluster
Onboard Cluster to ExtremeCloud IQ
Onboarding a Cluster to ExtremeCloud IQ
Account Registration
Cloud Visibility
Configure Persistent Connection to ExtremeCloud
Appendix
Appendix A: ExtremeCloud IQ - Site Engine Integration with ExtremeCloud Edge
Appendix B: Migrate Virtual IQ Account
Export VIQ Account
Import VIQ Account
Appendix C: Node Additions and Replacements
Add Nodes
Replace a Node
Revision History
Revision
Publish Date
Description of Updates
AA
05 June 2026
Initial publish
AB
22 June 2026
Updated
with additional IP ranges.
