Take the following steps to configure the Virtual Router Redundancy Protocol (VRRP) IP addresses.
- Navigate to .
- From the Interfaces list, select the data access interface that you configured from the System Startup Wizard for (Port 1).
The Port Configuration Settings menu displays.
Under VRRP, assign
VRRP IP addresses to this port. Do the following:
Select Add and then enter
the VRRP Address and optional Comments that
describe the address.
Repeat the preceding substep if you want
to add additional VRRP addresses. You can add up to ten VRRP addresses
on a data port but only a single VRRP address on an ICC port.
To delete an address,
select the adjacent
icon.
Set the Priority and
Router ID. If
you've assigned multiple VRRP addresses to this port, these values apply to all
VRRP addresses on this port.
- Repeat this process in each of the nodes of the cluster.
Each cluster node must have the same VRRP addresses
and the same Router ID, but a unique Priority setting. The Priority setting
determines which node in the cluster is the Primary node. The node with the
higher priority is considered the default Primary node.
