The Device screen is the default view of all floors within any site managed by your ExtremeLocation Essentials account. When you select a site that you manage, this screen displays for the default floor for that site.
The Device screen displays all visitors devices seen on a floor on the floor map. Use this screen and its controls to filter and view the different client types (Visitors/Staff, Assets, and BSS) for a floor in a site within your ExtremeLocation Essentials managed network.
If a client's data is deleted in ExtremeCloud IQ, all configured, cached, Live, and Historical data related to that client is also deleted from ExtremeLocation Essentials.
If Reset VIQ is selected in ExtremeCloud IQ, all configured data for locations, devices, and clients is cleared from ExtremeLocation Essentials. In addition, all cached, Live, and Historical data related to that VIQ is cleared from ExtremeLocation Essentials.
To view device details for a floor:
The following device types can be viewed:
Visitors/Staff - Use this option to filter to devices that are classified as Staff and Visitors.
Assets - Use this option to filter to devices classified as Assets. These devices are those that your company might want to track.
BSS Devices - These devices, within your monitored environment, broadcast BSS (Basic Service Set) identifiers that indicate that they offer Wi-Fi connection to any device that may want to connect to it. BSSs with a managed environment can be authorized or unauthorized. Unauthorized BSSs are a security risk for the environment they are found in and need to be monitored for and the devices tracked.
Refer to topic Common Tools for information on the other tools available for use in the Sites screens.
The screen immediately refreshes to display the selected device type.
When you select Current, the screen displays all devices of the type selected in the Device Type field. This screen refreshes periodically.
When you select Historical, the screen expands to display a few more fields that you can use to select a particular period of time for which you want to view the devices for.
If you want to filter to a particular device, you can use the Search by field to do so. You can search for a device using its MAC address or its name.
This toolbar changes when you change the device type selected in the Device Type control.
By default, the Floors view displays all the devices classified as Employee/Visitor that are seen on the floor.
The Device Classification toolbar enables you to quickly filter to the devices category you are interested in. The category labels are based on the Industry vertical that you have configured in ExtremeCloud IQ . For more information about Device Classifications, see Device Classification Settings.
The screen refreshes to display the data for the selected device classification.
Device View displays Associates and Visitors labels for the Retail vertical. Filter the display for Associates only, Visitors only, or show All devices.
When you choose BSS, the screen refreshes to display only those devices that broadcast themselves as capable of creating a hotspot within your network.
If the system cannot triangulate a device within 60-120 seconds, then the last known position of the device can display on the map using the past 48 hours of locate data. The time of the last known position displays when you hover over the device.
Provide the following additional parameters:
