EPG: Network Property Description
The EPG Network Property Description allows you to configure “description” per EFA tenant ctag which gets configured on the SLX as VLAN/BD description.
The default value of “description” is as below:
Network Type Description
L2 Extension Tenant L2 Extended VLAN/BD
L3 Extension Tenant L3 Extended VLAN/BD
L3 Handoff Tenant L3 Hand-off VLAN/BD
L3 Extension EVPN IRB Tenant L3 Extended IRB BD
You can provide the EPG network “description” during EPG create and EPG update (ctag-range-add) operations.
2.3.2 to 2.4.0 Upgrade Handling
During the upgrade from EFA 2.3.2 to EFA 2.4.0, for all the EPG networks, the default “description” is determined and the app-state is set to “cfg-refreshed” so that the user triggers DRC (in EFA 2.4.0) to push the derived network “description” on to the SLX.
EPG Create
efa tenant epg create --name <epg-name> --tenant string <tenant-name> --port <list-of-phy> --po <list-of-po>
               --switchport-mode <access |trunk | trunk-no-default-native>
               --ctag-range string <ctag-range> --ctag-description <ctag:description>
EPG Update
efa tenant epg update --name <epg-name> --tenant <tenant-name> --operation <ctag-range-add>
                --ctag-range <ctag-range> --ctag-description <ctag:description>
efa tenant show
|   Name   |  Type   | VLAN Range | L2VNI Range | L3VNI Range | VRF Count | Enable BD |         Ports         |
|  bdTen1  | private |   21-30    |             |             |    10     |   true    | 10.20.246.15[0/11-20] |
|          |         |            |             |             |           |           | 10.20.246.16[0/11-20] |
| vlanTen1 | private |   11-20    |             |             |    10     |   false   | 10.20.246.16[0/1-10]  |
|          |         |            |             |             |           |           | 10.20.246.15[0/1-10]  |
efa tenant vrf create –name ten1vrf1 –tenant vlanTen1
efa tenant vrf create –name ten2vrf2 –tenant bdTen1
VLAN Based L2 Extension EPG
efa tenant epg create --name ten1epg1 --tenant vlanTen1 --port 10.20.246.15[0/1],10.20.246.16[0/1]
--switchport-mode trunk --ctag-range 11-12 --ctag-description 12:Ten1VLANNW1
VLAN Based L3 Extension EPG:
efa tenant epg create --name ten1epg2 --tenant vlanTen1 --port 10.20.246.15[0/1],10.20.246.16[0/1]
--switchport-mode trunk --ctag-range 13-14 --ctag-description 14:Ten1VLANNW2 --anycast-ip
13:10.0.13.1/24 --anycast-ip 14:10.0.14.1/24 --vrf ten1vrf1
VLAN Based L3 Handoff EPG
efa tenant epg create --name ten1epg3 --tenant vlanTen1 --type l3-hand-off
--port 10.20.246.15[0/1],10.20.246.16[0/1] --switchport-mode trunk --ctag-range 15-16 --ctag-description 16:Ten1VLANNW3
BD Based L2 Extension EPG
efa tenant epg create --name ten2epg1 --tenant bdTen1 --port 10.20.246.15[0/11],10.20.246.16[0/11]
--switchport-mode trunk --ctag-range 21-22 --ctag-description 22:Ten2BDNW1
BD Based L3 Extension EPG
efa tenant epg create --name ten2epg2 --tenant bdTen1 --port 10.20.246.15[0/11],10.20.246.16[0/11]
--switchport-mode trunk --ctag-range 23-24 --ctag-description 24:Ten2BDNW2 --anycast-ip
23:10.0.23.1/24 --anycast-ip 24:10.0.24.1/24 --vrf ten2vrf
efa tenant epg show --detail
Switch Config
Rack1-Device1# show running-
config bridge-domain
bridge-omain 1 p2mp
 description Tenant L2 Extended BD
 pw-profile default
 logical-interface ethernet 0/11.21
 bpdu-drop-enable
 local-switching
bridge-domain 2 p2mp
 description Ten2BDNW1
 pw-profile default
 logical-interface ethernet 0/11.22
 bpdu-drop-enable
 local-switching
bridge-domain 3 p2mp
 description Tenant L3 Extended BD
 pw-profile Tenant-profile
 router-interface Ve 4099
 logical-interface ethernet 0/11.23
 bpdu-drop-enable
 local-switching
 suppress-arp
bridge-domain 4 p2mp
 description Ten2BDNW2
 router-interface Ve 4100
 logical-interface ethernet 0/11.24
 bpdu-drop-enable
 local-switching
 suppress-arp
bridge-domain 4093 p2mp
 description Tenant L3 Extended IRB BD
 router-interface Ve 8189
 bpdu-drop-enable
 local-switching
bridge-domain 4094 p2mp
 router-interface Ve 8190
 bpdu-drop-enable
 local-switching
Rack1-Device2# show running-
bridge-domain 1 p2mp
 pw-profile default
 bpdu-drop-enable
 local-switching
 pw-profile default
 bpdu-drop-enable
 local-switching
 bpdu-drop-enable
 local-switching
 suppress-arp
 bpdu-drop-enable
 local-switching
 suppress-arp
 bpdu-drop-enable
 local-switching
 bpdu-drop-enable
 local-switching
Rack1-Device1#show running-config vlan
vlan 11
 description Tenant L2 Extended VLAN
vlan 12
 description Ten1VLANNW1
vlan 13
 router-interface Ve 13
 suppress-arp
 description Tenant L3 Extended VLAN
vlan 14
 router-interface Ve 14
 suppress-arp
 description Ten1VLANNW2
vlan 15
 description Tenant L3 Hand-off VLAN
vlan 16
 description Ten1VLANNW3
Rack1-Device1#
Rack1-Device2# show running-config vlan
vlan 11
vlan 12
vlan 13
 suppress-arp
vlan 14
 suppress-arp
vlan 15
vlan 16
Rack1-Device2#
