Configure Local IP for EPG
You can add or delete local IP address configurations during the following operations:
  • Creating EPGs
  • Adding or deleting CTAG ranges
  • Adding or deleting VRFs
The Local IP address is configured on the VE interface assigned to a particular tenant network. You can select different local IP addresses for each device in a tenant network.
  1. To configure local IP during EPG create operations, run the following commands:
    efa tenant epg create --name ten1epg1 --tenant tenant1 --vrf red
    --switchport-mode trunk --ctag-range 11 --anycast-ip 11:10.10.11.1/24
    --port 10.24.80.150[0/1],10.24.80.151[0/1]
    --local-ip 11,10.24.80.150:11.22.33.41/24 --local-ip 11,10.24.80.151:11.22.34.41/24
    efa tenant epg show
    Tenant: tenant1
    Description:
    Type: extension
    Ports : 10.24.80.151[0/1]
          : 10.24.80.150[0/1]
    Port Property : switchport mode     : trunk
                  : native-vlan-tagging : false
    NW Policy: ctag-range       :11
                  : vrf                 : red
                  : vrf-State           : vrf-device-created
                  : vrf-Device-State    : provisioned
                  : vrf-App-State       : cfg-refreshed
                  : l3-vni              : 8190
    Network Property [Flags : * - Native Vlan]
    | Ctag | L2-Vni | Anycast-IPv4 | Anycast-IPv6 | BD-name |    Local IP (Device-IP->Local-IP)   |  Dev-state  |   App-state   |
    | 11   | 11     |10.10.11.1/24 |              |         |  10.24.80.151->11.22.34.41/24       | provisioned | cfg-refreshed |
    |      |        |              |              |         |  10.24.80.150->11.22.33.41/24       |             |               |
  2. To delete local IP during EPG update operations, run the following commands:
    efa tenant epg update --name epgv20 --tenant tenant1 --operation
    local-ip-delete --local-ip 11,10.24.80.150:11.22.33.41/24
    efa tenant epg show
    Tenant        : t3
    Description   :
    Type          : l3-hand-off
    Ports         : 10.20.50.209[0/27]
    POs           : posv9
    NW Policy     : ctag-range          : 201-202
                  : vrf                 : vrfv20
                  : l3-vni              : 5110
    | 201  | 201    |              |              |         |  10.20.50.209->44.4.4.5/24           | provisioned | cfg-in-sync   |
    |      |        |              |              |         |                4444:44::5/120        |             |               |
    |      |        |              |              |         |  10.20.50.208->44.4.4.4/24           |             |               |
    |      |        |              |              |         |                4444:44::4/120        |             |               |
    | 202  | 202    |              |              |         |  10.20.50.209->44.4.5.5/24           | provisioned | cg-in-sync    |
    |      |        |              |              |         |                4444:45::5/120        |             |               |
    For 'unstable' entities, run 'efa tenant po/vrf show' for details
  3. To add local IP during EPG update operations, run the following commands:
    efa tenant epg update --name ten1epg1 --tenant tenant1
    --operation local-ip-add --local-ip 11,10.24.80.150:11.22.33.41/24
    efa tenant epg show
    Tenant: tenant1
    Description:
    Type: extension
          : 10.24.80.150[0/1]
                  : vrf                 : red
                  : l3-vni              : 8190
    | 11   | 11     |              |              |         |  10.24.80.151->11.22.34.41/24            | provisioned | cfg-in-sync |
