You can add or delete anycast-ipv4 and anycast-ipv6 to or from an existing tenant network using the EPG update anycast-ip-add or delete operations on an L3 EPG.
Typical usage of the API from Openstack Integration is as follows:
efa tenant epg update --name <epg-name> --tenant <tenant-name>
--operation <anycast-ip-add | anycast-ip-delete>
--anycast-ip <ctag:anycast-ipv4> --anycast-ipv6 <ctag:anycast-ipv6>
efa tenant epg show --detail
Tenant : vlanTen1
Description :
Type : extension
Ports : 10.20.246.15[0/1]
: 10.20.246.16[0/1]
POs :
Port Property : switchport mode : trunk
: native-vlan-tagging : false
NW Policy : ctag-range : 11
: vrf : ten1vrf1
: l3-vni : 8188
Network Property [Flags : * - Native Vlan]
| Ctag | L2-Vni | Anycast-IPv4 | Anycast-IPv6 | BD-name | Local IP (Device-IP->Local-IP) | Ctag-Description | Mtu-IPv6-ND | ManagedConfig-IPv6-ND | OtherConfig-IPv6-ND | Dev-state | App-state |
| 11 | 11 | 10.0.11.1/24 | | | | Tenant L3 Extended VLAN | | False | False | provisioned | cfg-in-sync |
efa tenant epg update --name ten1epg1 --tenant vlanTen1 --operation anycast-ip-add --anycast-ipv6 11:10::1/123
Tenant : vlanTen1
Description :
Type : extension
: 10.20.246.16[0/1]
POs :
: vrf : ten1vrf1
: l3-vni : 8188
| 11 | 11 | 10.0.11.1/24 | 10::1/123 | | | Tenant L3 Extended VLAN | | False | False | provisioned | cfg-in-sync |
efa tenant epg update --name ten1epg1 --tenant vlanTen1 --operation anycast-ip-delete --anycast-ipv6 11:10::1/123
efa tenant epg show
Tenant : vlanTen1
Description :
Type : extension
: 10.20.246.16[0/1]
POs :
: vrf : ten1vrf1
: l3-vni : 8188
| Ctag | L2-Vni | Anycast-IPv4 | Anycast-IPv6 | BD-name | Local IP (Device-IP->Local-IP) | Mtu-IPv6-ND | ManagedConfig-IPv6-ND | OtherConfig-IPv6-ND | Dev-state | App-state |
| 11 | 11 | 10.0.11.1/24 | | | | | False | False | provisioned | cfg-in-sync |
For 'unstable' entities, run 'efa tenant po/vrf show' for details
