Tenant “show” CLI Consistency
With the proposed changes, each entity (Tenant, PO, VRF, BGP Peer-Group, BGP Peer, EPG) will have the below possible "show" flavours:
Brief Detail
  • Displays the brief info of all the instances belonging to all the tenants in the format "efa tenant <entity-type> show" e.g. "efa tenant po show".
  • Displays the brief info of all the instances belonging to a given tenant in the format "efa tenant <entity-type> show --tenant <tenant-name>" e.g. "efa tenant po show --tenant ten1".
  • Displays the brief info of a particular instance in the format "efa tenant <entity-type> show --name <entity-instance-name> --tenant <tenant-name>".
    efa tenant po show
    --name ten1po1 --tenant ten1
  • Displays the detailed info of all the instances belonging to all the tenants in the format "efa tenant <entity-type> show --detail" e.g. "efa tenant po show --detail"
  • Displays the detailed info of all the instances belonging to a given tenant in the format "efa tenant <entity-type> show --tenant <tenant-name> --detail" e.g. "efa tenant po show --tenant ten1 --detail"
  • Displays the detailed info of a particular instance in the format "efa tenant <entity-type> show --name <entity-instance-name> --tenant <tenant-name> --detail"
    efa tenant po show
    --name ten1po1 --tenant ten1 --detail
