Logging and Log Files
Log directories vary by deployment type and by application.
EFA logs are saved to the following locations:
In multi-node, high availability deployments, logs are replicated on all nodes in the cluster.
The efa system supportsave script gathers all logs, database dumps, pod logs, and deployment details and then compresses them into a ZIP folder. You can share this ZIP folder with Extreme support personnel when troubleshooting an issue.
