EFA High Availability Failover Scenarios
EFA high availability provides for uninterrupted service in several different scenarios.
For information about deploying EFA for high availability, see the Extreme Fabric Automation Deployment Guide, 2.3.0.
SLX device failure
When an SLX device fails, the SLX-OS and the EFA services running on TPVM go down for the failed node. The time it takes for failover to the standby node varies depending on whether the K3s agent node is actively running the EFA services. The following image depicts a scenario in which one SLX device fails.
SLX device failure in a two-node cluster
Failover to the redundant device occurs when one device fails
SLX device failure on the active K3s agent node
When the K3s agent node is actively running EFA services on a node that fails, K3s initiates failover and starts the EFA services on the standby node. Failover is complete when EFA services are running on the newly active K3s agent node (node 2).
Because the GlusterFS replicated volume remains available during failover, the K3s cluster data store and the EFA data store remain operational.
When the failed node is again operational, it becomes the standby node. The K3s agent node continues to run EFA services from node 2. When both nodes are up and K3s is running, all services fetch the latest data from devices to ensure that EFA has the latest configurations.
SLX device failure on the standby K3s agent node
When the K3s agent node is the standby and is not running EFA services, no failover actions occur if this node fails. EFA services continue to run on the active node without interruption.
TPVM failure
The TPVM failure scenario is similar to that of the SLX device failure scenario. The only difference is that SLX-OS continues to operate.
Two-node failure
In the unlikely event that both nodes in the cluster fail at the same time (for reasons such as a power failure or the simultaneous reboot of SLX devices), EFA has built-in recovery functionality. If the cluster is not automatically recovered within 10 minutes of power being restored or within 10 minutes of the TPVM being rebooted, then you can manually recover the cluster.
For more information, see .
