Extreme Fabric Automation Administration Guide Version 2.4.2.
Tenant Services Provisioning
Administered Partial Success
> APS Behaviour of Tenant Configuration
Published April 2021
Preface
Getting Help
Providing Feedback
What's New in this Document
Introduction to Extreme Fabric Automation
EFA Microservices
REST API Documentation for EFA
EFA System Management
Verify the Running System and Services
Log in to EFA
EFA User Authentication and Authorization
EFA RBAC Policy Enforcement
Assign and View EFA Roles
Configure an External LDAP Server
EFA Certificate Management
Monitoring EFA Status
Verifying EFA System Health
EFA System Backup and Restoration
Back up and Restore the EFA System
Change the Host Name or IP Address
Display EFA Running Configurations
Audit Trail Logging
Transfer of Audit Trail Data
Logging and Log Files
Data Consistency
Periodic Device Discovery
Persistent Configuration
Drift and Reconcile
Drift and Reconcile Limitations in Tenant Service
Idempotent Operations
Rollback Scenarios for Data Consistency
EFA High Availability Failover Scenarios
Multiple Management IP Network
Configuration Supporting Multiple Management IP Networks
Add and Delete Management Routes
Adding and Deleting Management Subinterfaces
Example configurations
Sub-Interface creation
Keepalived Configuration
Ingress Controller Configuration
Fabric Infrastructure Provisioning
Fabric Service Overview
IP Fabric and Clos Orchestration Overview
SLX Device Prerequisites for Fabric Service
Clos Overview
Configure a 3-Stage Clos Fabric
Configure a 5-Stage Clos Fabric
Overview of Day-0 Operations for a Non-Clos Fabric
Supported Non-Clos Topologies
Configure a Non-Clos Small Data Center Fabric
IP Multicast Fabric Provisioning
IP Multicast Fabric Overview
Supported Platforms
Configure EFA IP Multicast Fabric
Device Configuration
Configure Drift and Reconcile on Multicast Fabric
Viewing Fabric Details
Tenant Services Provisioning Overview
Provisioning a Tenant
Clos Fabric with Non-auto VNI Maps
Clos Fabric with Auto VNI Map
Layer 3 Network Services
Configure Description on Port Channel
Configure Minimum Link Count on Port Channel
Configure Backup Routing on Tenant VRF
Configure Static VRF Route
Configure BFD on static VRF route
Configure Local-ASN on tenant VRF
Enable Graceful restart on Tenant VRF
Configure Resilient Hashing on tenant VRF
Enable Graceful Restart (GR) on tenant VRF
Configure MaxPaths on tenant VRF
Configure Redistribute attribute on tenant VRF
EPG: Network Property Description
Update anycast-ip on existing tenant network
Configure IPv6 ND on tenant network
Configure the BFD Session Type for an Endpoint Group
Configure CEP Cluster Tracking for EPG
Enable Cluster Tracking on CEP Interfaces
Configure Local IP for EPG
Configure MTU for an Endpoint Group
BGP as a Service
BGP Peer Group
BGP Peer
IPv6 Support
Exclusion of VLANs and Bridge from Cluster Instance
Sharing Resources Across Tenants using Shared Tenant
Centralized Routing
Prepare CLOS Fabric for Centralized Routing
Prepare Non-CLOS Fabric for Centralized Routing
Enable Centralized Routing on Tenant VRF
Configure physical routers for centralized routing on Tenant VRF
Configure anycast-ip on Tenant EPG
Configure local-ip on Tenant EPG
Configure static route on tenant VRF
Configure static route BFD on Tenant VRF
Configure peer-group on Tenant BGP
Configure static peer on Tenant BGP
Confgure Dynamic peer on Tenant BGP
Administratively Manage a Device State
Existing behaviour in EFA 2.3.0
APS: Pre Provisioning Support by modifying the target device list to include the MCT neighbour
APS: Deletion support for the pre-provisioned config
Tenant “show” CLI Consistency
EFA Device Management
Device Image Management
Hitless Firmware Upgrade
Upgrading the Super-Spine Firmware in Clos
Upgrading the Spine Firmware in Clos
Upgrading the Firmware of an MCT Leaf Pair with Dual-Homed Servers in Clos
Upgrading the Firmware of a Three-Rack Centralized MCT Pair in Non-Clos
Upgrading the Firmware of a Three-Rack Ring MCT Pair in Non-Clos
Upgrade Device Firmware in a High Availability Deployment
Fabric-wide Firmware Download
Roll Back Device Firmware
Traffic Loss Scenarios
Switch Health Management
Monitor Switch Health
Device Configuration Backup and Replay
Configure Backup and Replay
Return Material Authorization
Replace a Faulty Device
SLX Device Configuration
Compare a Device
Enable Maintenance Mode on SLX Devices
Configure Physical Port Speed
Configure Breakout Ports
Configure MTU at the Interface or System Level
Change the Admin Status of an Interface
EFA Event Management
RASlog Service
RASlog Operations
Notification Service
Event Synchronization and Missing Event Handling
EFA as SNMP Proxy
