You should be familiar with STP defaults before you make configuration changes.
Parameter |
Default setting |
Spanning-tree mode |
By default, STP, RSTP, and MSTP are disabled |
Bridge priority |
32768 |
Bridge forward delay |
15 seconds |
Bridge maximum aging time |
20 seconds |
Error disable timeout timer |
Disabled |
Error disable timeout interval |
300 seconds |
Port-channel path cost |
Standard |
Bridge hello time |
2 seconds |
Parameter |
Default setting |
Spanning tree |
Enabled on the interface |
Automatic edge detection |
Disabled |
Path cost |
2000 |
Edge port |
Disabled |
Guard root |
Disabled |
Hello time |
2 seconds |
Link type |
Point-to-point |
Portfast |
Disabled |
Port priority |
128 |
BPDU restriction |
Restriction is disabled. |
