The following commands support MAC movement detection and resolution.
Command |
Details |
mac-address-table mac-move detect |
Enables MAC movement detection. Disabled by default. Once enabled, use the no form to disable. |
mac-address-table mac-move limit |
Defines the movement threshold. Enter a value; default is 20, range is 3 through 500. |
mac-address-table mac-move action |
Define the action to be taken when MAC movement exceeds the specified threshold. Default action is RASlog. Enabled by default when mac-address-table mac-move detect is enabled. |
mac-address-table mac-move auto-recovery enable |
Enables auto-recovery on the port/interface after a shutdown action. Enabled by default when shutdown is enabled. |
mac-address-table mac-move auto-recovery time |
Sets the auto recovery time. Default auto-reovery time is 5 minutes. Range is 3 through 30 minutes. |
clear mac-address-table mac-move shut-list |
Clears all entries from the shutdown list. |
show bridge-domain [bd-id] logical-interface |
LIF output has been modified to indicate when the LIF is down due to mac-movement. |
show mac-address-table mac-move shut list |
Displays information for all entries in the shutdown list. |
show mac-address-table mac-move |
Displays all mac-move configurations. |
show vlan |
Output has been modified to indicate when the LIF/port is down due to mac-movement. |
show vlan detail |
show vlan interface port-channel |
Output has been modified to indicate when the VLAN is down due to mac-movement. |
