Use the show cfm command to display the Connectivity Fault Management (CFM) configuration.
device# show cfm Domain: md1 Index: 1 Level: 7 Maintenance association: ma5 MA Index: 5 CCM interval: 100 ms Bridge-Domain ID: 50 Priority: 7 MAID Format: Short MEP Direction MAC PORT VLAN INNER-VLAN PORT-STATUS-TLV ==== ========= ========= ==== ==== =========== =============== 1 UP 609c.9f5f.700d Eth 1/9 50 -- N
For the show cfm command to generate output, you must first enable CFM in protocol configuration mode.
