The following examples display PW client and bridge domain information for VPLS and VLL MCT.
The following example displays the configuration and state information of the PW client on the MCT cluster.
device# show cluster Cluster c1 ================ Cluster State: Active Bringup Delay: 90 seconds Configured Member Vlan Range: All Active Member Vlan Range: 1 Configured Member BD Range: All Active Member BD Range: 501 No. of Clients: 2 Peer Info: ========== Peer IP: 4.1.1.10, State: Up Peer Interface: Ethernet 0/4, Source IP: 4.1.1.11 Keep-Alive: ========== IP: 10.24.8.220, State: Up Interface: Management 0 (mgmt-vrf), Source IP: 10.24.8.221 Client-Isolation Role: Primary Client Info: ============ Interface Id Description Local/Remote State Exceptions --------- -- ----------- ------------------ ---------- Port-channel 10 1010 Up / Up PW 34816 Up / Up
device# show cluster client-pw Client Info: ============ Interface: PW, client-id: 34816, Deployed, State: Up Description: Local Vlans: Local Bridge Domains : 501 Remote Vlans : Remote Bridge Domains : 501 Number of DF Vlans : 0 Elected DF for vlans : Number of DF Bridge Domains : 1 Elected DF for Bridge Domains : 501
device# show cluster member bridge-domain BD-ID VNI-ID Forwarding state ------- ------ ------------------- 501 4597 Up
device# show bridge-domain 501 Bridge-domain 501 ------------------------------- Bridge-domain Type: MP, VC-ID: 501 MCT Enabled: TRUE Description: Number of configured end-points: 3, Number of Active end-points: 3 VE id: N/A, if-indx: N/A, Local switching: TRUE, bpdu-drop-enable: TRUE PW-profile: default, mac-limit: 0 VLAN: 501 Tagged ports: 1(1 up), Un-tagged ports: 0 (0 up) Tagged ports: po10.501 Un-tagged ports: VNI: 4597 Tunnels: 1(1 up) Tunnels: tu32769.4597 Total VPLS peers: 1 (1 Operational): VC id: 501, Peer address: 9.9.9.9, State: Operational, uptime: 12 min 44 sec Load-balance: False, Cos Enabled: False, Tunnel cnt: 1 rsvp to_a9 (cos_enable:False cos_value:0) Assigned LSPs count:0 Assigned LSPs: Local VC lbl: 800769, Remote VC lbl: 866325, Local VC MTU: 1500, Remote VC MTU: 1500, Local VC-Type: 5, Remote VC-Type: 5 Local PW preferential Status: Active, Remote PW preferential Status: Active Local Flow Label Tx: Disabled, Local Flow Label Rx: Disabled Remote Flow Label Tx: Disabled, Remote Flow Label Rx: Disabled Local Control Word: Disabled, Remote Control Word: Disabled
The following example displays the MAC address table for bridge domain of an MCT cluster.
device# show mac-address-table bridge-domain
Type Code - CCL:Cluster Client Local MAC
CCR:Cluster Client Remote MAC
CR:Cluster Remote MAC
VlanId/BDId Mac-address Type State Ports/LIF/PW/T
501 (B) 0000.0500.0200 Dynamic Active 9.9.9.9
501 (B) 0000.0500.0500 Dynamic-CCL Active Po 10.501
Total MAC addresses : 2
The following example displays all the MAC addresses learned from other VPLS PE nodes over MCT bridge domains.
501 (B) 0000.0500.0200 CR Active Tu 32769 (4.1.1.11)
501 (B) 0000.0500.0500 CCR Active Po 10.501
