Follow these steps to o shut down MSTP either globally, on a specific interface, or a specific VLAN.
device# configure terminal
Shut down MSTP globally and return to privileged EXEC mode.
device(config)# protocol spanning-tree mstp device(config-mstp)# shutdown device(config-mstp)# end
Shut down MSTP on a specific interface and return to privileged EXEC mode.
device(config)# interface ethernet 0/2 device(conf-if-eth-0/2)# spanning-tree shutdown device(conf-if-eth-0/2)# end
Shut down MSTP on a specific VLAN and return to privileged EXEC mode.
device(config)# vlan 10 device(config-vlan-10)# spanning-tree shutdown device(config-vlan-10)# end
device# show spanning-tree device#
device# configure terminal device(config)# vlan 10 device(config-vlan-10)# spanning-tree shutdown device(config-stp)# end device# show spanning-tree device# copy running-config startup-config
Shutting down MSTP on a VLAN is used in this example.
