Follow these steps to enable and configure PVST+ on an interface.
For detailed descriptions of the parameters and features, see the sections STP parameters and STP features.
device# configure terminal
device(config)# protocol spanning-tree pvst
device(config-pvst)# interface ethernet 0/3
device(conf-if-eth-0/3)# no spanning-tree shutdown
device(conf-if-eth-0/3)# spanning-tree link-type point-to-point
device(conf-if-eth-0/3)# spanning-tree priority 64
device(conf-if-eth-0/3)# spanning-tree cost 10000
device(conf-if-eth-0/3)# spanning-tree vlan 10 cost 10000
device(conf-if-eth-0/3)# spanning-tree guard root
Root guard protects the root bridge from malicious attacks and unintentional misconfigurations where a bridge device that is not intended to be the root bridge becomes the root bridge.
device(conf-if-eth-0/3)# spanning-tree port-fast bpdu-guard
device(conf-if-eth-0/3)# spanning-tree port-fast bpdu-filter
device(conf-if-eth-0/3)# exit
device# show spanning-tree brief
Spanning-tree Mode: PVST Protocol
Root ID Priority 4096
Address 768e.f805.5800
Hello Time 8, Max Age 25, Forward Delay 20
Bridge ID Priority 4096
Interface Role Sts Cost Prio Link-type Edge
Eth 0/3 DES FWD 200000 64 P2P No
Observe that the settings comply with the formula set out in the STP parameters section, as:
(2 × (forward delay - 1)) ≥ maximum age ≥ (2 × (hello time + 1))
or in this case :38 ≥ 25 ≥ 18.
device# configure terminal device(config)# protocol spanning-tree pvst device(conf-pvst)# interface ethernet 0/3 device(conf-if-eth-0/3)# no spanning-tree shutdown device(conf-if-eth-0/3)# spanning-tree link-type point-to-point device(conf-if-eth-0/3)# spanning-tree priority 64 device(conf-if-eth-0/3)# spanning-tree cost 10000 device(conf-if-eth-0/3)# spanning-tree vlan 10 cost 10000 device(conf-if-eth-0/3)# spanning-tree guard root device(conf-if-eth-0/3)# spanning-tree port-fast bpdu-guard device(conf-if-eth-0/3)# exit device# show spanning-tree device# copy running-config startup-config
