You can delete a specified IP address, or all IP addresses, from an interface.
				From privileged EXEC mode,
					access global configuration mode.
					device# configure terminal
		  Access the interface from which you are deleting the IP address.
			 device(config)# interface ethernet 1/5
				To delete a specific IP address
					from the interface, run the no ip address command with the IP
					address and the mask.
					device(config-if-eth-1/5)# no ip address 10.53.5.3/24
				To delete all IP addresses from
					the interface, run the no ip address command.
