A hold timer can be configured on a VRRP-enabled interface to set an interval, in seconds, before a backup device becomes the master VRRP device.
A hold timer is used when a VRRP-enabled device that was previously a master device failed, but is now back online. The backup device has a higher priority than the current VRRP master device. Before assuming the role of master VRRP device again, the backup device waits for the time period specified in the hold timer. This task is supported in both versions of VRRP and VRRP-E, but the configuration below is for VRRPv3.
		  Enter the
			 configure terminal command to access global configuration mode.
device# configure terminal
		  Enable IPv6 VRRP-E.
device(config)# ipv6 protocol vrrp-extended
 In this example, virtual Ethernet (ve) interface configuration mode is entered and the interface is assigned with a VLAN number of 2018.
		  Enter the
			 interface ve
			  command with an associated vlan number.
device(config)# interface ve 2018
		  Enter an IPv6 address for the interface using the
			 ipv6 address
			  command.
device(config-ve-2018)# ipv6 address 2001:2018:8192::122/64
		  Enter the
			 ipv6 vrrp-group
			  command with a number to assign a VRRPv3 group to the device.
device(config-ve-2018)# ipv6 vrrp-group 18
 In this example, VRRP group configuration mode is entered.
		  Enter the
			 description
			  command to enter text that describes the virtual router group.
device(config-vrrp-group-18)# description Product Marketing group
		  Enter the
			 advertisement-interval command with a number representing milliseconds.
device(config-vrrp-group-18)# advertisement-interval 3000
			  Note    In VRRPv3, the advertisement-interval is in milliseconds.
		  Enter the
			 hold-time command with a number representing seconds.
device(config-vrrp-group-18)# hold-time 5
		The following example configures and enables a VRRPv3 session and adds a VRRP group description. A hold time of 5 seconds is configured. This example also contains appropriate
		  virtual-ip command configuration not included in the task above.
device# configure
device(config-vrrp-group-18)# virtual-ip fe80::2018:1
device(config-vrrp-group-18)# virtual-ip 2001:2018:8192::1
