A BGP4 default route is the IP address
		0.0.0.0 and the route prefix 0 or network mask 0.0.0.0. For example, 0.0.0.0/0 is a default
		route.
By default, a BGP4 device does not originate and advertise the default BGP4 route.
			You can configure a BGP4 device to advertise the default IPv4 route to all BGP4
			neighbors and to install that route in the local BGP4 route table.
 The default route must be present in the
			local IPv4 route table.
				Access global configuration
					mode.
					device# configure terminal
				Access BGP configuration mode.
					device(config)# router bgp
				Access IPv4 address family
					unicast configuration mode.
					device(config-bgp-router)# address-family ipv4 unicast
				Configure the device to
					originate and advertise the default BGP route and to install that route in the
					device(config-bgp-ipv4u)# default-information-originate
			This example summarizes the commands in this procedure.
