BGP Flowspec Considerations
  When a device is downgraded to a release
		that is earlier than 18r.2.00, the BGP flowspec feature does not work.
		Data plane considerations
				- Only non-VPN IPv4 BGP flowspec is
					supported.
- Match types other than the 12 BGP flowspec
					NLRI sub-component types described in Distribution of Flowspec Rules by BGP are considered unknown. A flowspec NLRI that contains an unknown match type
					is considered invalid and is not advertised or installed in the hardware.
- The following TCP flags are not supported:
						- Explicit Congestion
							Notification Echo (ECE)
- Congestion Window Reduced
							(CWR)
- Two-byte TCP flags are not
					supported.
- When a TCP flag sub-component is larger than
					one byte, a RASlog message is triggered and it is not installed in the hardware.
					However, it is advertised to peer devices.
- Only the IsF bit is supported for BGP
					flowspec NLRI sub-component type 12 (Fragment). DF, FF, and LF bit functionality
					is not supported.
- When the match criteria of a stanza in a
					flowspec route map requires an NLRI length that is greater than 4095, the route
					map is not installed or advertised by BGP.
- Actions other than the four BGP flowspec
					traffic filtering actions described in BGP Flowspec Traffic Filtering Actions are considered unknown. For a flowspec NLRI that contains an unknown action:
						- The unknown action
							(user-defined extended community or unknown action) is not
							installed.
- The remaining flowspec
							rules are installed.
- The flowspec NLRI is
							advertised to peers with the unknown extended communities.
- Copy or mirror action is not
					supported.
- When a rate-limiting action is set under a BGP flowspec rule, the operational
					rate value may differ from the rate value specified in the flowspec rule because
					operational values are selected in multiples of 22 kbits per second.  Note    When
						the rate-limiting action under a BGP flowspec rule is set to a value that is
						lower than 22 kbits per second, matched data traffic is dropped.
- With the default TCAM profile, BGP flowspec
					routes configured with the following match criteria can be advertised but not
					installed in the hardware:
						- IP fragment
- Packet length
- ICMP code
- ICMP type
 To maximize the BGP flowspec match criteria and actions supported in the
					hardware, a BGP flowspec profile must first be enabled in the hardware by the
						profile tcam
						border-routing command.
- Traffic-marking (set dscp) is not supported in the default TCAM profile.
- With the default TCAM profile, flowspec can be used only when there are no
					user-defined VRFs.
- BGP flowspec rules are applied on
					all Layer 3 interfaces of the specified VRF.
- IPv4 BGP flowspec rules are applied only to
					IPv4 data traffic. They are not applied to IPv6 data traffic.
- CAM sharing is not supported in the border
					routing TCAM profile.
- Several match commands, such as match dscp, support
					a range
					option. Use the range
					option with caution because many TCAM entries may be created when the rules are
					expanded.
- Redirection to multiple nexthop addresses is
					not supported. When multiple redirect nexthops are configured, only the first
					valid, reachable nexthop is used. If the first nexthop becomes invalid or
					unreachable, then the next configured, valid, reachable nexthop is used.
- Matching of traffic flow with
					subsequent flowspec rules (terminal-action) is not supported.
- Each flowspec rule may be expanded to several
					access control list (ACL) rules in TCAM. When TCAM is full, a RASlog message is
					displayed. However, the BGP transit functionality of advertising and receiving
					flowspec rules can continue when TCAM is full or a flowspec rule is not
					installed in TCAM.
- BGP flowspec rules are prioritized over
					policy-based routing rules. Policy-based routing rules are prioritized over ACL
					rules.
Control plane considerations
				- A maximum of 1,000 (configured and received)
					flowspec rules is a best practice.  Note    In BGP RIB-in, there is no
						hard-coded limit for BGP flowspec routes. When sufficient memory exists, BGP
						RIB-in receives more routes. However, a maximum of 1,000 routes is a best
						practice.
- Any match criterion or traffic action in a BGP flowspec route that is not
					supported in the hardware is still received and advertised by BGP.
- Dampening and soft reconfiguration is not
					supported for the BGP flowspec address family.
- The nexthop path attribute is not added to
					BGP flowspec routes by default.
