Configurations that are not specific to address family configuration are available in the BGP global configuration mode.
device(config-bgp-router)# ?
Possible completions:
  address-family                Enter Address Family command mode
  always-compare-med            Allow comparing MED from different neighbors
  as-path-ignore                Ignore AS_PATH length for best route selection
  auto-shutdown-new-neighbors   Auto shutdown new neighbor
  capability                    Set capability
  cluster-id                    Configure Route-Reflector Cluster-ID
  compare-med-empty-aspath      Allow comparing MED from different neighbors
                                even with empty as-path attribute
  compare-routerid              Compare router-id for identical BGP paths
  confederation                 Configure AS confederation parameters
  default-local-preference      Configure default local preference value
  describe                      Display transparent command information
  distance                      Define an administrative distance
  enforce-first-as              Enforce the first AS for EBGP routes
  fast-external-fallover        Reset session if link to EBGP peer goes down
  install-igp-cost              Install igp cost to nexthop instead of MED
                                value as BGP route cost
  local-as                      Configure local AS number
  log-dampening-debug           Log dampening debug messages
  maxas-limit                   Impose limit on number of ASes in AS-PATH
                                attribute
  med-missing-as-worst          Consider routes missing MED attribute asleast
                                desirable
  neighbor                      Specify a neighbor router
  timers                        Adjust routing timers
	 The following neighbor configuration options are allowed under BGP global configuration mode:
device(config-bgp-router)# neighbor 2001:2018:8192::125 ?
  advertisement-interval   Minimum interval between sending BGP routing updates
  as-override              Override matching AS-number while sending update
  capability               Advertise capability to the peer
  description              Neighbor by description
  ebgp-btsh                Enable EBGP TTL Security Hack Protection
  ebgp-multihop            Allow EBGP neighbors not on directly connected
                           networks
  local-as                 Assign local-as number to neighbor
  maxas-limit              Impose limit on number of ASes in AS-PATH attribute
  next-hop-self            Disable the next hop calculation for this neighbor
  password                 Enable TCP-MD5 password protection
  peer-group               Create Peer Group
  remote-as                Specify a BGP neighbor
  remove-private-as        Remove private AS number from outbound updates
  shutdown                 Administratively shut down this neighbor
  soft-reconfiguration     Per neighbor soft reconfiguration
  static-network-edge      Neighbor as special service edge, static-network
                           shall not be advertised if installed as DROP
  timers                   BGP per neighbor timers
  update-source            Source of routing updates
